Brief Description: Primered landing gear and misc rudder pedal work
Solvent wiped the landing gear legs and sprayed a coat of Spray Max Epoxy primer in the inboard surfaces of both legs
Sanded the micro on the wing tips and applied neat epoxy pin hole filler using a 1" diameter paint roller. This method worked better than the squeegee method because it left a more uniform epoxy coating. Applied a second and third coat after each of the previous coats gelled.
Sprayed primer on the outboard surfaces of the landing gear legs
Removed the brake pedal assembly. Fabricated and installed a new lock pin for the brake pedal position adjustment (the old one was shorter than spec). Installed both brake fluid reservoirs on the master cylinders
