Brief Description: Alternate air cable and SV amps hookup
Sanded the wing tips and applied some more micro near the lenses.
Installed the alternate air door and cable.
Realized that I had applied the label for ELT ACCESS upside down so I scraped it off and reapplied it. Fortunately I had a spare.
Hooked up the wiring for the Sky View voltage and Amperage readings. Installed an inline blade fuse holder to protect the wiring. Terminated one of the wire pigtails from the fuse holder with a small ring terminal and soldered the other end to the wires that measure amps for the Skyview EMS (and volts wire which was spliced with the high side amperage wire). Covered the splices with shrink tubing and ziptied the wiring to the existing large gage wiring.
Alternate air door bracket and cable in place
Sky view voltage and amps wiring hooked up
Inline fuse holders to protect voltage and amps wiring
