N983LK
Date:  7-9-2020
Number of Hours:  4.00
Brief Description:  Heater cable
Fabricated another bracket for the heater cable and mounted it on the lower Zee brace on the right hand side. This will most likely be the final position since it's out of the way but allows easy access. Drilled holes and mounted Adel clamps to support the cable between the bracket and the heater valve. Drilled a hole in the LH vertical firewall brace, installed a snap bushing and routed the cable through it. Cut the heater cable to length but left the center wire long.
Temporality hooked up the cable to the valve and tested the operation of the cable and valve.
Removed the brackets for the heater valve and alternate air door. Scuffed, cleaned and primed the brackets.
