N983LK
Date:  7-3-2020
Number of Hours:  4.00
Brief Description:  Wing tips and control cable FW passthroughs
Finished fitting the replacement wing tip lenses to the wing tips. I decided to use just two screws on each lens versus the six I had installed previously. Drilled out the rivets for four of the nut plates on each wing tip. Applied epoxy flox to the open holes.
Opened holes in the firewall to 1 1/8 inch diameter and drilled mounting holes for eyeball firewall fittings for the throttle, mixture and prop cables. Applied high temp sealant to the inner flanges and screwed the flanges in place. Wiped off excess sealant.
