Brief Description: Bracket for ANL fuse and ammeter shunt
Installed the mounting trays for the IFD-440 and the GMA-245
Installed the CO Guardian
Wrapped round-it abrasion protection wrap around the wire bundles where they will contact the cabin vent tubes.
Terminated one end of a length of RG400 coax with a BNC connector. This cable will be for the IFD-440 GPS antenna.
Fabricated a bracket to mount the ANL current limiter and the ammeter shunt. The bracket bolts in place where the plans show the brake fluid reservoir (I'm using individual reservoir on each brake cylinder).
Terminated the #6 wires from the VP-X pro and the starter contactor with 5/16 inch ring terminals and installed them on one side of the ammeter shunt.
Installed the battery and tested the system by activating the BAT switch. The battery contactor activated and the system powered up.
ANL current limiter (top) and Ammeter shunt (bottom)
