Brief Description: Wingtips part 20 and started the firewall forward
Filed the flox on the edges of the wingtips. Removed the electrical tape
Removed the ailerons from the wings
Fared in the lower surface of the LH wingtip to the wing tip lens with micro. Filled the gap under the canopy skirt with micro.
Supported the fuselage with the support stand. Removed the rotisserie and the protective aluminum sheet that I had placed between the Rotisserie and the firewall.
Installed the heater box and the starter contactor on the firewall. Installing the starter contractor required drilling out two rivets in the firewall and installing two nut plates.
