N983LK
Date:  5-25-2020
Number of Hours:  3.00
Brief Description:  Wingtips part 17 and canopy shims
Spread dry micro on the wing tip lens recesses on the bottom sides of the LH and RH wing tips to act as liquid shim between the lenses and wing tips. Clecoed the lenses in place to shape the liquid shim while it dries.
Completed fitting shims between the canopy frame and canopy skirt. Used washer stacks on most of the location other than the forward vertical braces which only needed fiberglass strips which were cut from the excess from the canopy skirt. Began supergluing washer shim stacks together.
