N983LK
Date:  10-28-2020
Brief Description:  Landing gear toe-in check
Torqued the three inboard landing gear leg bolts on each side with Lynn’s help.
Installed the landing gear axles on the gear legs. Taped wood spacers on to the axles. Ran a monofilament line on the forward surface of the spacers to check the toe-in/toe-out. From the initial check it looks like the RH side is OK but the LH side is toed in about 3/4 of a degree so. The spec is for a max of 1/4 degree toe in or toe out. I can correct this by installing shims between the axels and the landing gear le
