N983LK
Date:  10-24-2020
Number of Hours:  2.50
Brief Description:  Landing Gear Legs back on
Lifted the fuselage with an engine hoist and put a higher saw horse under the spar. Reinstalled the landing gear legs, loosely installed the inboard bolts and torqued the outboard bolts to 240 in-lbs. Measure the gaps between the outboard landing gear brackets and the wear plates. The gap is less than the specified .030” in spots so the brackets will have to come off to be filed down a bit.
Received the Dynon Skyview wi-fi adapter I had ordered. Plugged it into one of the USB ports on the back of the skyview display and configured it to communicate with the i-pad. Tested its operation with Foreflight. It seems to work well. I was able to transfer flight plans between the two and I received traffic info on Foreflight.
Gear legs on
Gear legs on
Measuring the gaps under the outboard brackets
Skyview Wi-fi adapter
