N983LK
Date:  10-17-2020
Brief Description:  Sanding the micro on the windscreen
Sanded the micro on the windscreen. Used a section of a 4 inch diameter yoga roller as a sanding block for the micro around the lower front edge.
Applied another layer of micro to the lower front edge.
Sanding block
Sanding block
First coat sanded
First coat sanded
Second coat applied
Second coat applied
