N983LK
RV-8
More canopy fiberglass work
Laid up fiberglass build ups on the remainder of the windscreen fairing
Sanded the RH HS tip and sprayed the top of it with high build primer
Wet sanded (400 grit) the UV smooth prime on the RH canopy skirt
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
