Brief Description: Wing tips part 16 and canopy work
Sanded the epoxy pinhole filler on the canopy forward trim strip. Sprayed it with high build primer
Spread dry micro on the wing tip lens flanges on the top sides of the LH and RH wing tips to act as liquid shim between the lenses and wing tips. Clecoed the lenses in place to shape the liquid shim while it dries.
Removed the canopy and began placing shims between the canopy frame and canopy skirt
