Brief Description: Wing tips part 12 and back to the canopy
Sanded the RH wing tip while it was on the wing. Applied wet coat of micro/epoxy to both the top and bottom of the wing tip.
Installed the LH wing tip on the LH wing.
Sanded the OML surface of the canopy skirt. Cured epoxy had bled from the IML when I filled the pin holes with skim coats of epoxy. Clecoed the skirt in place to the canopy and frame on the fuselage to determine what needs to be done next to tweak the fit.
