N983LK
RV-8
Wing tips part 9
Removed peel ply from RH upper wing tip stiffeners.
Laid up two plies over foam cores in LH wing tip upper IML
Hot glued foam core in place for RH wing tip lower stiffener. Applied epoxy/micro/cabosil filets.
Cured upper stiffeners in RH wing tip
Layed up upper stiffeners in LH wing tip
Foam core for RH lower stiffener
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
