Fabricated a bracket to mount the nav/stobe CPC connector and VOR/LOC antenna connector on the end of the RH wing. Fabricated a bracket to mount the nav/strobe CPC connector on the end of the LH wing. Riveted the brackets to the outboard wing ribs of each wing.
Terminated the coax in the RH wing with a male BNC connector. Mounted it on the bracket with an Adel clamp.
Cut and terminated the RG400 coax in the RH wingtip with a female BNC connector.
Installed Adel clamps on the outboard wing ribs to hold the landing light wiring. Terminated two lengths of black 18 AWG wire with ring terminals and bolted them to the end wing ribs. These will serve as ground wires for the landing and taxi lights. The red wire seen in the pictures below mock up the power wire for the taxi light in the RH wing. The actual wire will be routed through the conduit in the wings after the wings are installed.
