N983LK
RV-8
Wing tip lenses part 2
Finished fitting the lens to the RH wing tip. Drilled six #40 holes at the lens mounting screw locations. Clecoed lens in place.
Began cutting and fitting lens for LH wing tip.
Holes for mounting RH nav/strobe
RH Nav/strobe and lens in place on RH wing tip
Fitting LH wing tip lens
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
