Sanded the plywood closeout on the vertical stab tip to shape
Applied a layer of T-88 structural adhesive to the rudder tip cap and the rudder flange (after cleaning and scuffing the bond lines) and clecoed the tip in the rudder. Installed the blind rivets
Removed the canopy skirt, cleaned up the aft underside. Mixed up some epoxy/flox and applied it where needed on the IML side of the skirt. Clecoed the skirt back in place to mold the flox in place as it cured.
Installed the elevators in the horizontal stab and clecoed the elevator tips in place.
Trimmed the horizontal stabilizer caps to fit. Laid out the rivet hole locations and match drilled the skins and tips.
