N983LK
Date:  6-20-2019
Brief Description:  Canopy rear stop
Applied a second coat of truck bed paint to the rear baggage floor. Let it dry and removed masking.
If built per the plans the canopy on the RV-8 will not stop when sliding aft until the inner latch handle contacts the F807 bulkhead and this will likely scratch and dent the bulkhead. Most builders add some sort of a stop to the canopy tracks to prevent that from happening. I perused Van's Airforce and looked at a number of solutions. The one I liked the best uses a piece of rubber inside the aft end of the tracks to provide a contact point for the canopy rollers. I decided to duplicate that concept.
I purchased a 4"x4"x1" rubber jeweler's bench block on Amazon. Tonight I cut two 7/16" wide by 2 1/2" long strips from the block and sanded down the height a little bit so they fit inside the rails. The aft end was cut on a slight angle so it will sit flush against the F807 bulkhead. I drilled three 1/2" holes in each block to reduce weight and maybe allow them to give a little bit if the canopy rollers slam against them. I still need to cut relief notches in the aft bottom corners of each of them so that they clear the aft most screw in the rails.
Painted rear baggage floor
Cutting rubber block for stops
Rear canopy stops trial fit
