N983LK
RV-8
Canopy frame part 2
Drilled the slider block for the clevis pin.
Fabricated aluminum strips to tape/clamp to the frame to help determine what adjustments need to be made.
Used ratchet straps to pull the front bow of the canopy frame closed to match the fuselage. Did this numerous times with fit checks in between.
Slider block drilled for clevis pin
Fitting the canopy
A little tweeking
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
