N983LK
Date:  5-27-2019
Number of Hours:  5.00
Brief Description:  Canopy frame part 2
Drilled the slider block for the clevis pin.
Fabricated aluminum strips to tape/clamp to the frame to help determine what adjustments need to be made.
Used ratchet straps to pull the front bow of the canopy frame closed to match the fuselage. Did this numerous times with fit checks in between.
Slider block drilled for clevis pin
Fitting the canopy
Fitting the canopy
A little tweeking
A little tweeking
