N983LK
RV-8
Canopy slide rail part 3
Laid out the location of the canopy slider spacer on the top centerline of the aircraft. Taped the spacer in place.
Drilled the 9 mounting hole locations through the spacer into the fuselage skin.
Countersank the 9 mounting hole locations and opened them up to #28 for #6 screws. Opened up the holes in the skin to #28.
Riveted the slider cap to the spacer
Clecoed the slider rail to the fuselage and started bolting it in place.
Slider spacer located on tailcone with screw holes drilled
Canopy rail riveted together.
Slider rail clecoed in place.
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
