N983LK
Date:  4-28-2019
Number of Hours:  6.00
Brief Description:  Finished battery and ELT access door mods
Riveted the doublers to the rear baggage shelf. Riveted the hinges for the battery access door. Riveted the ELT door hinge. The shelf mounted hinge half for the ELT door won't be riveted until after paint since the door hinge won't be removable,
Tounged up the primer on all parts.
The parts are ready for paint. The hartwell latches will be riveted in place after paint because I want to bake the paint on the doors and I'm concerned that the 250 degrees will damage the latches.
Drew up a diagram for the E-bus bus block. The diagram will be printed on a sticker which will be affixed to the bottom of the battery access door since the fuse block will be accessed via the door
Mods complete.
Mods complete.
E-bus fuse block diagram
Inside
Inside
