N983LK
Date:  3-6-2019
Brief Description:  Primed panel and deburred aft cabin covers
Temporarily connected the oil temperature sensor to its feed wire and a ground. Tested its operation to make sure the SV-EMS-220 functions properly since the CO Guardian isn't reading correctly on the Skyview. The oil temp indicated 64 degrees which is correct.
Wet sanded and re-primed the instrument panel
Deburred the LH and RH Aft cabin covers
