N983LK
RV-8
Roll bar and avionics fan wiring
Removed the roll bar.
Primed the switch light mounting blocks.
Drilled holes in the canopy plates for snap bushings to pass the switch light wires through
Cut, labeled and installed the avionics fan power wire in the VP-X Pro
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
