Brief Description: Skyview radio test and landing/taxi light test
Removed seats, forward seat ramp and forward cabin floor.
Temporarily installed the Com 2 antenna.
Powered up the Skyview system, VPX and audio panel. Plugged in a headset.
Tested the transmit and receive functionality of the SV-COM. Checked good. Both push to talk switches worked.
Checked the switch assignments in the VP-X configure
Connected the taxi and landing lights to their wires with test leads. Functionally tested them and both worked properly. Configured the VPX for wig-wag of the taxi and landing lights. Functionally tested (with threshold airspeed set to zero). Worked properly.
Functionally tested boost pump wiring. Wire was powered on when boost pump switch was turned on.
