Labeled the VP-X power wire for the Skyview display. Cut and solder spliced the power wire to the two power input wires in the Skyview display harness. Covered the solder splice with shrink tubing.
Labeled the wire for the IFD-440 main power input. Plugged it into the VP-X Pro J10 connector and routed it to the IFD-440 location.
Relabeled the three conductor wires for the roll and pitch trim servos.
Organized the neatened up the wire bungles near the SV-EMS and installed zip ties
