N983LK
Date:  10-12-2018
Number of Hours:  2.50
Brief Description:  Panel switchs
Cut the switch wires for the ALT switch, auto pilot switch and avionics master switch to length, labeled them and terminated the VP-X pro end with a D-sub pin.
Drilled an additional hole in the panel between the holes for the BAT switch and the LH mag switch for a starter enable switch. When I had the panel cut by Stein Air I was thinking that the starter enable switch would be under the panel out of sight but I have since decided that it makes more sense to put it on the panel
Installed the switches and switch guards on the panel
Engine switches
Engine switches
Light etc switches
Light etc switches
