Soldered the two power wires for the GMA 245 audio panel to a VP-X Pro pre-terminated wire and pinned the wire into its connector. Routed the two ground wires to the ground block location.
Terminated the GMA 245 end of the GMA 245 harnesses with D-sub pins and installed them in the D-sub connector.
