Brief Description: Skyview network wiring and audio panel trial fit
Cut a 3 foot Skyview network harness into two pieces and terminated the cut ends of both with D-sub connectors. Installed the custom length harnesses between the SV-AP panel and the SV-knob panel and between the SV-AP panel and the SV-Hub.
Terminated the ends of the four roll servo network wires that were routed in front of the panel with a D-sub connector and installed it on the SV-Hub.
Installed 1.5 ft SV harness from the SV display to the SV-Hub and from the SV display to the SV-Com panel.
Temporarily installed the Garmin audio panel in the instrument panel
Neatened up the wire bundle that runs along the forward mid-cabin brace.
