N983LK
Date:  7-1-2018
Number of Hours:  6.00
Brief Description:  Sub panel work
Cut the opening in the LH subpanel for the CO Guardian. Drilled the mounting holes and installed nut plates.
Drilled the LH sub panel for the back-up push to talk switch. Temporarily mounted the switch.
Cut the opening and drilled the mounting holes for the Skyview USB port. This will be used for uploading Skyview software updates.
CO Guardian Installed in panel
Cutting holes for Skyview USB port
USB port in place
USB port in place
