N983LK
RV-8
Sub panel work
Cut the opening in the LH subpanel for the CO Guardian. Drilled the mounting holes and installed nut plates.
Drilled the LH sub panel for the back-up push to talk switch. Temporarily mounted the switch.
Cut the opening and drilled the mounting holes for the Skyview USB port. This will be used for uploading Skyview software updates.
CO Guardian Installed in panel
Cutting holes for Skyview USB port
USB port in place
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
