N983LK
Date:  6-27-2018
Number of Hours:  3.00
Brief Description:  More wiring
Started hooking up wires to the VP-X routed pre-terminated wires, that were included with the VP-X Pro wire kit, from the VP-X, through the RH gear tower and to the back-up switches on the lower switch panel. Routed the power wires from the back up switches to com 1 (the IFD-440) and the boost pump. Ran the front USB outlet power wire from the VP-X pro to the USB outlet and ran the USB outlet ground wire from the outlet to the firewall where the forrest of tabs grounding point will be. Labled all wires.
