Drilled mounting holes through the aft mounting angles of the VP-X Pro and SV-COM-425 shelf as well as the upper aft fuselage brace. Drilled and countersank the holes in the SV-COM-425 shelf angle for nut plates. Scuffed and primed the angle and attached the nut plates.
