N983LK
RV-8
Under floor wiring continued
String tied the wires from the LH wing together.
Began routing wires for the roll servo from the CPC connector on the RH fuselage wall, through the spar and RH gear tower and forward of the panel.
LH wing wire bundle secured with string ties
LH wing wire bundle routed to RH side
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
