N983LK
Date:  4-14-2018
Number of Hours:  4.00
Brief Description:  LH antenna doubler and harness bracket
Cut a replacement doubler for the LH com antenna. The replacement is thicker than the previous ones and doesn't include the snap bushing tab. I also fabricated an angle stiffener which will be used to support a stand off for an Adel clamp for the pitot-static lines and cables which will go through the LH outboard spar penetration. The angle will also serve to stiffen the skin where the pitot-static and wiring through the Adel clamp will pull up on the lower fuselage skin.
Terminated the end of a length of RG400 with a BNC connector. This will be the cable for the LH com antenna.
