Fabricated a zee bracket to hold an adel clamp to secure the AOA line where it exits the fuselage.
Drillled 7/16 inch holes for the AOA and pitot llines to exit the fuselage and installed grommets.
Secured the pitot-static llines in place on the click studs and routed the lines through the antenna doubler snap bushing but its difficult to route the static line from the snap busing and through the spar so I need to consider ways to secure the lines and wires because once the doubler is riveted in place it will too hard to install and remove the lines.
