N983LK
Date:  4-5-2018
Brief Description:  Pitot/static tube and wire guide
Designed a new doubler to use in place of the one I made for the LH com antenna. The new one will have a tab which will be bent at 90 degrees to the double and have a snap bushing installed. The pitot-static lines and some of the wires that pass through the LH OB spar penetrations will pass through the snap bushing to keep them clear of the LH aileron pushrod
