N983LK
RV-8
Misc stuff
Drilled the grip wire exit hole in the new pilot's stick (3/8").
Scuffed, painted and baked the pilot's stick
Removed the switches, switch guards and USB port from the lower switch panel. Scuffed, cleaned and primed the lower switch panel.
Installed the fiber washer on the nut side of the pilo'ts headphone jack (When I installed the jacks I only had 3).
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
