Disassembled the wires from the head set jacks, shortened the wires from the lemo connector to reduce the likelihood of noise in the headset and re-soldered.
Experimented with various shrink tubing and rubber sheet to "neaten up" the look of the wiring and jacks since they're visible through the holes in the mid-cabin brace plates
Drilled holes the F804C bulkheads and the LH side instrument panel for snap bushing and routed the headset wires to the forward avionics bay
