Used the scrap cut from the stick to trial fit one of the stick grips. Drilled a 29/64" hole in the tube 1/2" from the top. Cut the recommended 1/2" by 1.25" slot at the top of the tube on the aft side for wire clearance per the instructions. Bolted the grip in place
