N983LK
Date:  1-13-2018
Number of Hours:  4.00
Brief Description:  Stick and stick grip
Cut 5 of the stick grip ground wires and spliced them together and to a black wire that will run out of the stick and serve as a common ground. This was done to reduce the size of the wire bundle so the exit hole can be smaller
Cut from stick to length.
Drilled 1/4 inch hole in the aft side above the pivot point. Experimented with running the grip wires through the tube and out the hole. Determined the hole wasn't big enough for the number of wires. Opened the hole up to 5/16"
