N983LK
RV-8
Re-populating aft fuselage avionics bay
Riveted the standoffs for mounting the static line Adel clamps to the F809 upper bulkhead.
Reinstalled the static lines between the static ports.
Reinstalled the ADAHRS shelf
Reinstalled the mounting plate for the ADSB receiver and Skyview hub.
Reinstalled the wire harnesses and Adel clamps
Started hooking up the pitch bellcrank and autopilot pitch servo
Static line mounts riveted in place
Equipment going back in
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
