N983LK
RV-8
Battery tray, static port and rudder exit cover in
Prosealed the static ports and rudder cable exit fairings in place. Riveted rudder exit covers.
Fabricated a support angle for the RH aft end of the battery tray. It attaches to the F808 bulkhead to stiffen the tray.
Fabricated a bracket to clamp to the flap actuator for the lower end of the flap position push rod.
2x4 applying bonding pressure to static ports
OML view of static ports
Rudder cable exit fairings
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
