Brief Description: Rudder cable exit fairings and flap position senso
Dimple countersank the three rivet holes in the rudder cable exit fairings. Dimpled two of the corresponding holes in the skin and machine counter sank the bottom ones since they were backed up by the lower longerons. Clecoed the fairings in place. Later they will be bonded to the skins with pro-seal in addition to the three rivets in each.
Began fabrication of a bracket for the flap position sensor
Cable exit fairings trimmed to shape
Exit fairings clecoed in place
The start of a bracket for the flap positon sensor
