N983LK
Date:  2-15-2017
Number of Hours:  2.50
Brief Description:  Elevator linkage adjustment
Adjusted various rod ends to make both pilots' sticks perpendicular to the longerons.
Measured the elevator throw. The down travel is 27.5 degrees. The maximum allowable is 25 degrees. I'm going to call Van's Tech Support but I think I'll probably make a new elevtor control stop with a longer tab which I'll then file down to get the requred travel.
The up travel is around 20 degrees which is less than the minimum specified travel of 25 degrees so I'll need to remove some material from the aft stop.
