Brief Description: Elevator bushings and horn drilling
Measured the gap between the elevator center bearing and the elevator horns. Subtracted the thickness of the large washer and fabricated bushings from 1/4" ID tubing. Installed the bushings, washers, bolt, washer and nut.
Clamped the elevators in the neutral positon. Determined that the right elevator was slightly aft of the left one, so I removed the RH elevator an per the plans located and drilled a #12 hole 3/8" back from the forward edge and 3/8" up from the bottom of the horn. Reinstalled the RH elevator.
