N983LK
RV-8
Drilled mounting holes for landing gear.
Re-measured all dimensions for the landing gear alignment. Made some final adjustments and drilled all of the holes.
Final result is a toe in of approximately .15 degree on both sides which is within acceptable tolerance per Vans
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
