Brief Description: Started landing gear installation
Started installation of the grove landing gear.
Flipped the fuselage over and leveled it out. Final drilled the 7/16" and 1/4" holes through the floor and gear tower weldments. Drilled the wear plates to add a 7/16"hole corresponding to the ones in the inboard gear brackets. Bolted the gear legs in place using the 7/16" bolt.
