Fabricated another set of brake lines. This set is made to connect to the parking brake valve rather that the 90 degree fittings that the parking brake valve replaced. I'll keep the original set for use in the event I decide to take the parking brake off.
Update. These lines were later replaced to change the routing through the gear towers. off.
