Painted the F-808 bulkhead since it will be visible from the aft baggage compartment.
Touched up the paint on the F-807 bulkhead.
Back riveted the mid longerons to the aft side skins. Painted the section of the aft side skins that will be exposed in the aft baggage compartment.
Riveted the aft baggage rails to the aft baggage bulkheads. Clecoed the F807 bulkhead to the center section and riveted it to the outboard aft seat support ribs. Riveted the aft baggage bulkheads to the center sections.
Clamped the Dynon autopilot pitch servo brackets to the aft baggage bulkheads, laid out hole locations for -4 rivets and match drilled the brackets and bulkheads.
Clecoed the RH aft side skin in place on the upper longeron and center section. Drilled a few holes into the upper longer that I had missed before and opened up a few of the holes to 1/8" for oops rivets.
Stiffeners riveted to the aft side skins & baggage area painted
